Results 1 to 7 of 7
    Default Installing new bathroom tile over old??
    Is it possible to install new tile over existing wall tile in the bathtub area? If not what would be the next step after removing old tile. My guess would be to remove old adhesive and put down backerboard. Or would I have to gut the walls and start from scratch? Thank you. Owen
    Oct 2007
    Cedarburg, WI
    0
    Default Re: Installing new bathroom tile over old??
    Do it ritht, strip the walls to the studs & use a proper ceramic tile backer, You will have a finished project you can be proud of & happy with
    2,736
    From the timbre of your question it seems you don't have much tile experience. If that's the case I'd highly recommend either letting someone else do it or attending a tiling class given by one of the 'big-box' home improvement stores. Beyond that a short answer to your question would be that yes, the old tile must go before new tile is laid. If you're very careful and very lucky removing it you might not need new backer but don't count on that; it rarely happens except when the tile setting mortar was too dry the first time around or if the tile was dusty or dirty when set. You'd want to sc**** all the old mortar off in the first case and reskim it in the second. The new tile will project slightly more either way but it's usually workable. Doing a re-tile job makes a good DIY project but it takes a lot longer than you think it will so I hope you have another bathroom to use in the interim!
    MC
    Quote Originally Posted by owenpga View Post
    It's definitely possible. I've done it in my bathroom. There was a recent episode of Ask This Old House where Richard helped a guy install a shower basin, and the homeowner said he was simply tiling over the existing tile. It would seem like if it were ill-advised Richard would have said something to the viewers or they would have edited that part out.
    Regardless, it's held up fine in my bathroom. I was afraid the raised tile would look bad around the toilet, but it's not noticeable once it's been laid. In no way ideal, but if money is in extreme short supply, it's definitely possible.
    Aug 2009
    30
    I took a big box class and it helped. I installed my own beautiful Travertine Tile in my Kitchen remodel I recently finished.
    2009 kitchen remodel warrior
    asbolute black granite
    Antique White Hidden Content
    Travertine 18" x 18" floor tiles.
    It looks Great!!
    Jun 2009
    The Great Lake State
    22
    per the Tile Council Of America YES you can Tile Over Tile.
    (see TCNA detail TR712-09) with that said ,remember that the new Tile is bonded to the old so, it must be sound and well bonded , free of any bond breakers.(soap scum ,wax,oil,ect) Mechanical abrasion is recommended .
    I however ,do agree with the others that removing it back down to the studs is the way to go.
    Sep 2009
    florida
    598
    My suggestion is remove the old tile , use new backer board. If you tiled over the old tile. How would you handle the outside edges towards the exterior of the tub. It will always look like a remodel job, unless theres a finished bullnose tile to wrap around the old to hide the edge.
    Make sure you put some protection in the tub while removing and installing new tile. You dont want to damage the tub surface with adhesive or drop a tile.
