    Default replacing bi-fold door slide guide
    I'm trying to replace the slide guide but am having trouble getting the pin to depress enough to where I can position it to fit between the two springs in the guide. Any suggestions?
    7,240
    Default Re: replacing bi-fold door slide guide
    Is this the pin on the top of the door that engages the track? You may have to lower the door a little bit, or lift it off the lower hinge point to engage the pins on the top of the door first, then reset the lower hinge point.
