    Default install radient heating
    Where is the PEX installed in a floor that is already in? Is in done in the crawl space?
    Default Re: install radient heating
    If you google "radiant floor heat" there is plenty of information sites like this http://www.radiantdesigninstitute.com/ generally the pex would be installed between the floor joists and attached the underside of the sub floor .... as one method.
    There are other issues to consider such as insulation and radiant barriers as well.
