Thread: leaking pipe
    Default leaking pipe
    pvc pipe to copper pipe at the hot water heater is leaking how can i stop it.
    Georgia
    150
    Default Re: leaking pipe
    You'll have to replace the parts that are leaking. You can probably use a "shark bite" (or tech tight) on the copper and connect a new piece of cpvc onto the other end with a coupling.
