    Default more from the first time home owner
    Replace the ceiling fans.....one doesn't work the other only cools..... ADD ceiling fan to Master Bedroom.....And to the side porch....
    Paint the front bedroom/office
    Finish the laundry nook and add shelves
    Paint kitchen - I truly hate peach coloured walls
    Tear down the shed, after buying a new one and putting futher in the backyard, rather than right in the middle where previous home owners put it.
    Actually find out if there is anything in the attic and then install new attic access stairs.
    Clean out under the house and install vapor barrier
    kill all ants living under the house
    refinish the floors
    Oh yea I forgot the bathroom window......it needs to be replaced with something opaque, because currently everyone driving by can see INTO the bathroom and sadly the tub is right there so no hiding when you shower. Currently it has a curtain over it.
    Oct 2007
    132
    Default Re: more from the first time home owner
    Did you check to make sure your curtain is heavy enough? Some new houses by my sister & bro-in-law had the same thing, and I guess those folks thought no one could see in.... and then it was like they all realized it at once. SOme used stained glass, some the peel and stick stuff, and some put heavy blinds.
    If you haven't gotten something better, you might get some of the peel and stick vinyl to put on the window - but make sure it's opaque to the max. I did that for my small bathroom, but discovered before I put it on that it was ever so sheer, though it didn't look like it until I held it up. hah!
    1,387
    The house becomming the home... great memories.
