    Default Low water pressure in shower
    Had my previous post problem fixed, but now have low water pressure in the master bathroom, in the shower. Its coming out of the tub spout about medium level of what it should and when we try to convert over to the shower nothing comes out of the shower head. Water pressure is good everywhere else in the house. Appreciate any suggestions, thanks!
    Last edited by Bill Vanselow; 01-07-2008 at 12:06 PM. Reason: Update about water pressure in rest of house
    5,842
    Default Re: Low water pressure in shower
    Bill,
    Sounds like the plumber may have knocked some crud (a technical term) loose when he reworked the spout, the shut off valve may not be all the way open, or the washer in the shutoff valve disintegrated and is causing a blockage.
    I have a question for you. Your shower head it's new? If not maybe he has some chalk-stone on it and you should get rid of it.
