Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Default Re: Dripping Ceiling
    bp21901 ... good call ... I was wondering the same thing about the insulation covering the top plate of the wall.
  2. #12
    612
    One other question.....
    As I was looking at the pictures again, what is the white material at the end of the insulation by the eaves? I couldn't figure out what that was from the pic.
    Also added a couple pics of the "coffin" that sits on top of the stairs when they are closed.
ID:	527   Click image for larger version.
  3. #13
    7
    That is actually the rear of the facia board (gutters are on the outside of it) which is Azek. When I had the new roof and chinmey put on, I wanted the trim as much as possible to be Azek, no painting and if it gets chipped, its white all the way through, great stuff.
    OK, I see exactly how the box is made, pretty cool. Looks easy too, thank you!!
    >Bob
  4. #14
    6
    You could use a barometer(found in any garden section of a store), but It may not be very accurate unless the rooms are completely airtight.
    The other is look at the weather channel. What's the humidity outside? Most buildings(I'm guessing) that have a lot of "soft" building products such as drywall/ or carpet of wood probably retain a higher humidity level than metal framing etc.
    Don't know though. I think it's always good to have a dehumidifier.
    Get one and run it for 30 minutes. If the collection tank fills up quickly, then YOU GOTS LOTS OF WATER! heh
