    Unhappy Insulation over bathroom
    I am remodeling my bathroom, removing all drywall and insulation. I am wanting to know what type of insulation to use in the attic, kraft faced or non faced insulation or should I use a vapor barrier. Thanks in advance!
    Default Re: Insulation over bathroom
    If you are also doing the walls then I would recommend using unfaced bat insulation with a 6 mil plastic sheet vapor barrier for both ... ceiling and walls.... in my opinion the paper backed bats are useless as a vapor barrier.
    The important thing is to ensure the vapor barrier is sealed by using a house wrap tape over all joints of the plastic. The ceiling vapor barrier should overlap the wall's vapor barrier at least 6 inches and taped .
    The key is to make the vapor barrier is a sealed envelope.
    If you want the ultimate method for the vapor barrier :
    apply a thick bead of acoustic caulk to each stud , top and bottom plates as well as each ceiling joist.
    Then apply the 6 mil plastic and tape all seams.
    Hope this helps.
    Make sure you have proper ventilation because sealing your room is great-but a sealed room needs to have the moisture removed with exhaust-any build up of moisture will condense on cold surfaces which can lead to mold growth .
    Yes ... good point ... make sure there is a proper bathroom fan and use it.
