Results 1 to 9 of 9
    Pennsylvania
    246
    Default Routing water line
    Here in NC.
    The water meter is located on my property approx 3ft from my street.
    The black plastic 1/2" diamter PVC pipe connect from water meter to the house in a dumb way. It runs underneath the garage floor and exit to the right side of the garage.
    I like to re-route and replace the plastic 1/2'" PVC pipe underneath my earth driveway via 1" diameter white PVC pipe.
    I will be burying the white PVC pipe approx 18 inches to 24 inches below top surface of my earth driveway.
    Is that a good idea or not?
    FYI...
    (1)There is low frost line requirement in the area where I live.
    (2)It is more like "install the pipe wherever I want".
    Coventry, RI
    340
    Default Re: Routing water line
    Not positive about this but I don't believe that PVC pipe can be used for drinking water. I'm pretty sure it can only be used for waste and venting. The black pipe is most likely ABS which in some parts of the country is used for waste instead of PVC. I'm not a plumber so I'm not sure what the difference is. Your best bet is to check with your local inspector or a plumbing supply store.
    Pennsylvania
    246
    I should be clearer about this.
    I think it is call PEX tubing. If I call it PVC pipe then please accept my error in proper term.
    I want to run 1/2" diameter PEX tubing inside 1" white PVC pipe and buried it underneath my driveway.
    If I have a leak in the future then I do not have to dig up my driveway. I just pull out the PEX tubing on either end and install new PEX tubing.
    I live in NC too the clay is awful it would work but if in the future you add sprinkler pipe it may get confused with your pipe.Also run a trace wire while you are in the ground so you can trace it down the road. Just single 14g cu will do.
    www.infraredsurvey.com
    Pennsylvania
    246
    Quote Originally Posted by Infraredsurvey.com View Post
    Oh yeah, you're 100% correct. It is one damn tough soil.
    I really wish I could run underground sprinkler but due to extremely tough NC soil. I'm not going to do that.
    Good Idea.
    980
    Quote Originally Posted by BigWalt View Post
    Good Idea.
    isn't that what is also called rock?
