    Default Can I combine water heater/boiler/forced-air furnace?
    I have a space problem so If I could combine some or all it would be good. I have a gas forced-air furnace, a water heater and I need something to heat up some new infloor heating. My house is 800sq/ft. I'd consider a tankless water heater.
    Is there something that can take care of it all?
    443
    Default Re: Can I combine water heater/boiler/forced-air furnace?
    Do you have the forced air heating system with all the ducting in place and heating the home now???
    It might be possible to install a heat exchanger in one of the main ducts to supply HW to the in-floor system.
    Have you gotten any free estimates from any local heating contractors on how this might be done???
    6,047
    Quote Originally Posted by Watermelon View Post
    Here's a suggestion, and I know this will cause some harsh comments, Get a recirculating pump , hook it up to take hot water from your water heater through the in floor coils and back to the cold side. Control the pump with a thermostat.
    Added -keep the FA. and duct work as is.
