Thread: fred
    texas
    Exclamation fred
    house is a 1999 built we just been their a year had more insulation blown in attic o7' now seems ever time we take a hot bath or shower th walls in bedroom get wet from ceiling to the studs the studs are metal.we even turn exhaust fan on still no help????
    texas
    Default Re: wet walls ?
    Quote Originally Posted by rl_mowrey@hotmail.com View Post
    any suggestion on how to solve problem
    Default Re: fred
    Maybe it's just me ... I'm not quite sure what you are describing.
    7,586
    Default Re: fred
    Not just you.
    Wisconsin
    18
    Smile Re: fred
    Is the bath possibly an open concept in the master bedroom? I know that in our main bath when it is extremely cold out with the vent fan on we still have condensation on the bath ceiling and walls but that is mainly cause of no heat in that room.
    If not open concept in master bdrm then you have an issue. I'm confused also.
    Cris
    texas
    Default Re: fred
    our house was bulit with metal studs so when we take hot baths or really hot showers you can see the studs and the wall is wet where they are.the bath has no doors just two door openings to bathroom.it just started doing this since it got cold.
    Default Re: fred
    It's similar to what's known as "ghosting" in colder climates and due to lack of a thermo break ( or poor insulation).
    The cold will come through where the studs or joists are, more than anywhere else. If the humidity is fairly high in the house the cold parts of the wall or ceiling in front of the framing will attract the moisture. Make sure you have a bathroom fan on while showering and let it run for a long time after.
    Hope this helps.
