Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    NE Atlanta, GA
    16
    Default Re: Router me some ideas please!
    Since you are going to use a laptop, most already have built-in wireless capabilities -- so double check what it is capable before you go and purchase something that is more then your PC can support. If it doesn't have the option built-in, then you are free to choose what the protocol you want -- but that will mean you have to be careful about the interface card / USB connector that you use -- if you are not real PC savy -- take you laptop to a PC store -- and ask for a recommendation.
    Good luck -- BTW -- I am using built-in wireless adapters and a Linksys wireless router. If you have a printer -- check to see if the router accepts a printer port -- or if your printer supports wireless -- just more to get to work together. Most wireless routers will support most lesser speed protocols -- but again, don't buy more then your faster interface.
    Bob H
  2. #12
    New York
    Hi Natalie,
    I have a Linksys / Cisco Wireless-G, WRT54G. We have 4 laptops which all access through the wireless. It also has 4 hard wired ports, two of which go straight to desktops/servers, and one of which I have patched to a high speed switch with 3 desktops/servers connected. So, there are a total of 11 nodes on the LAN. This router allows for DHCP, as do most, for controlling the ip addresses automatically. The router connects to a DSL modem from Verizon. Everything works fine, although occasionally, e.g. 4-6 times a year, you need to power down the modem, or the router, or both and power them back up.
  3. #13
    May 2007
    17
    Smile Re: Router me some ideas please!
    Hey everyone! ***, I just wanted to thank you all for all of the information. You guys brought up things I hadn't even thought of...especially about interference....and I really appreciate it. I live in the middle of a 6 floor apartment building AND have a cordless phone, so I'm guessing I have to keep that in mind when I go to the store...
    Anyway, like I said, I just wanted to thank you for the ideas and if any others pop up, please just keep them rolling. I have a feeling this decision is going to take awhile for me, but I'll def keep you guys updated. Thanks again!
  4. #14
    These are some excellent suggestions. Wireless is definitely the way to go for setting up a home computer network.
    If available in your area, attend a continuing-ed class on wireless networking basics. If you purchased a wi-fi router already, take it with you to the class. The instructor might be kind enough to help you set it up the first time. Most wi-fi router/access points come with a setup wizard, which is great if you've never configured one before.
    I have a Linksys G at home, and rarely have problems with it. It's in the basement, and the signal is not slowed down by pipes and ducts in the floor above. Just enough signal strength to cover the house and patio, but no further. There are both PCs and Macs connected to the network.
    I am the technology assistant at our local library, and use a d-Link wireless access point there. It has a much stronger signal output, more than you would probably need at home. But it works well. Some patrons have problems with the wi-fi configuration on their laptops, but that is usually an easy fix.
    For the price and ease of use, go with a Linksys.
  5. #15
    Jun 2008
    13
    omg those were the days...
    Fishfool @ The Reef Tank
  6. #16
    Jun 2008
    Vienna, Virginia
    a linksys router should be a good fit for you..easy to setup
    Saving the world, one software at a time through Legacy Modernization | Hidden Content
