    Nov 2009
    Smile installing a wood stove into existing pipe?
    I have a gas water heater & furnace vented thru my basement wall, up into my chimney.
    Q. Can I add (into the 6" stovepipe) the vent of a wood burning stove into the same pipe? Assuming the stove will sit right next to the gas water heater.
    Thanks for your advice...
    6,047
    Default Re: installing a wood stove into existing pipe?
    No, you should not.
    Midwest
    179
    Absolutely, positively not. In case you wanted a second opinion.
    "Lead by Example"
