    Default brick plastered interior wall
    I am drywalling our dining room and our house is a row home. It was built in 1900. my problem is on the interior wall under the plaster is brick. how can i drywall this or how do you reccomend I finish this wall or whole room
    102
    Default Re: brick plastered interior wall
    You can strip the plaster off and fir the wall out and reboard or you can bond the bricks with bonding agent and replaster it.Just my 2 cents
    I'm not sure why you would remove the plaster and replace it. Anything you replace it with will be less durable. All old plaster needs is some maintenance and/or repair. Replacing plaster with sheetrock is like replacing rock with paper.? New plaster while better than sheetrock is not as good as the old plaster which gets better with age.
