    Talking Gunk on saw blade
    What can I use to remove the gunk that builds up on my miter saw?
    8,046
    Default Re: Gunk on saw blade
    Remove the blade from the saw and lay it on a scrap of plywood larger than the blade. Spray it down real good - both sides - with oven cleaner and let it sit for a bit, 10 - 15 minutes should do. Then, use a nylon bristled brush to scrub the sides and face of the teeth. then rinse well with a hose. Repeat if necessary, towel dry when finished cleaning.
    Follow precautions on label of cleaner.
    612
    Simple Green and an old tooth brush works pretty well for me.
    8,046
    Quote Originally Posted by bp21901 View Post
    Well, sure, if you want a non-toxic, bio-degradable, non-caustic cleaner.
    6,047
    Personally I prefer the Boeshield products both the blade cleaner and the T-9.
    Well it beats wearing a HazMat suit.
