    Default Fireplace Mantle Paint
    Our fireplace mantle was slightly burned and needs to be repainted. I have sanded down the damaged area and am ready to paint, but I am unsure if there is low flammable paint that is especially for this type of fireplace job? The previous house owner's paint was a gloss white, we would like to stay with that type of paint, if possible. Thanks for any advice!
    6,053
    Default Re: Fireplace Mantle Paint
    It's called Intumescent paint and here are a couple of links
    http://www.contegointernational.com/
    http://corporate.ppg.com/PPG/PAF/FPC...nt/default.htm
    But the best advice is to be careful not to build a bigger fire than the fireplace can handle.
    I am in the same situation with a slightly burned fireplace mantle. What can I say, I got a little carried away with my new fireplace Luckily the wood has not carbonized, but I was considering using one of these fireplace decorating kits and was wondering if anybody had an opinion on how that would work for a slightly well done mantle. Thanks in advance.
