    Nov 2009
    Question recessed lighting to normal ceiling fixtures
    I have several square recessed lighting fixtures in my home and I would like to change to regular lighting fixtures. What is the best way to remove the recessed fixtures and repair the ceiling to install the new fixtures?
    Shamokin, Pa.
    645
    Default Re: recessed lighting to normal ceiling fixtures
    Quote Originally Posted by homefix1039 View Post
    You may have to post more info on this one.
    wisconsin
    159
    sounds like a big job, is there a reason your changing out the recessed lights? if above the celing is the attic it shouldnt be to hard to do, just time consuming!! if not could be quite a task.
