    Default Spray Insulation
    I am building a new home in Massachusetts. I have been told 2 different methods of using spray insulation. One contractors said spay the walls and under the roof with no attic vents. The other suggestion was to spray the walls but use fibergalss bats on the ceiling with attic vents. Which is the best method?
    Default Re: Spray Insulation
    Is this a two story or 1 1/2 story home ?
    It is a 1 1/2 story home.
    Do you have an idea as to what size lumber will be used for the roof rafters ?
    Also will the walls of the upper floor be at the outside or will they be inset ( also known as pony or knee walls ) ?
