Results 1 to 8 of 8
    Question Open floor plan stairs
    I recently purchased a house that was built in the 40's with an open floor plan. My problem is that the staircase going to the second floor does not have any railings. I baught newel posts and balusters I would like to install but due to the way the staircase was constructed I would have to cut the newel posts at a 45 deg angle. Any ideas how I could attach these ? I have pictures if it would help understand my problem
    5,938
    Default Re: Open floor plan stairs
    Pictures of the staircase and the posts would help.
    as requested here are some pictures. I don't really want to install them in front of the stairs due to very minimal space.
ID:	405   Click image for larger version.
ID:	406   Click image for larger version.
ID:	407   Click image for larger version.
ID:	409   Click image for larger version.
ID:	410   Click image for larger version.
ID:	411   Click image for larger version.
ID:	412   Click image for larger version.
    980
    here is what I would do. take your posts and cut your angle on the bottom so that they will be plumb when installed then mount them on a 1 x 4 then mount your 1 x 4 to the stair runner
    5,938
    Or you could notch them and mount them on the side of the stair stringer.
    Metro Boston
    13
    When notching, how much can you take away? I have a 4 x 4 maple post made of two 2 x 4s glued together. Can I notch it to 2 x 4. The posts are about 6 feet apart.
    5,938
    I don't believe you would have any problem notching to the 2X4. That should leave more that enough for the strength you'll need.
