Results 1 to 10 of 11
    Pennsylvania
    246
    Default Electrical Nightmare
    Recently, I purchase Intermatic wall timer switch. [Special Thanks to Canuk for finding the correct item]
    Today I decide to install timer in place of regular living room wall switch. I couldn't believe what a mess it is.
    There is no ground wires connected.
    4 white wires were taped together.
    Wires were jammed inside the little dinky plastic box.
    ***, the previous installer should be sent to electric chair.
    Anyway, I did the best I could for temporary until tomorrow night I have to find deeper box and corrected all the errors.
    I measure the depth of this plastic box and I come up with 2" deep.
    Is there a box that have the depth of 2/34" or deeper?
    Shamokin, Pa.
    645
    Default Re: Electrical Nightmare
    It certainly looks like exceeded your fill requirements, or someone else did before you.
    Going by the pic, the box looks like an "old work" PVC box.
    And yes they do come in different depths.
    Pennsylvania
    246
    Originally there were on/off switch on left side of the box. I just put in timer switch today. You should've seen my face when I first remove the faceplate.
    I just hope deeper box will fit into existing hole. One way or another, I'll stop at Lowes tomorrow night and see what they have.
    7
    You are an ignorant phuck.
    Your box was already overfilled with the combo switch now you stuffed it like a sausage just like you stuff your fat face.
    You are not allowed to swap an ungrounded snap switch with a dimmer or a timer switch. You have no EGC but you installed it anyway, what a moron.
    A deeper box isn't your only problem.
    Pennsylvania
    246
    Quote Originally Posted by Dan Ackroyd View Post
    LMAO...nice try.
    Who said I left the ground disconnected?
    7
    there is no ground wires connected.
    You did you ignorant CannonBallRun phuck.
    Pennsylvania
    246
    Nice reading skills Leslie.
    You really think I actually leave ground wire disconnected?
    6,114
    Big Walt, As these types of boxes are very easy to remove and reinstall you might consider widening the hole and get a 3 or 4 gang.
    Back off ...
    It's time this forum got some active moderators to control things here.
    The deep South
    459
    A check of ISP addresses would go a long way to eliminating
    " trolls " like this .
