    Oct 2007
    11
    Default How do you install tile on an inside corner
    When I tile the inside corners of my shower should the tiles on the side wall be tight up against the back wall and the tile on the back wall overlap it or should they be equally spaced and filled with grout between them?
    Thanks
    Steve
    5,826
    Default Re: How do you install tile on an inside corner
    No mater how hard you push the tile against each other it will not be a sealed joint. I wouls space and grout.
    Oct 2007
    11
    Thanks guys for the quick response!!
    Steve
