    Question Breakfast Bar in a load bearing wall
    Recently purchased a Stone row home from the 20's. We are interested in putting a breakfast bar from the kitchen into the dining room wall, which supports the 2nd floor and is located directly above the main steel I beam that supports the middle of the house.
    The walls are plaster and we'd like to know where to start.
    5,842
    Default Re: Breakfast Bar in a load bearing wall
    You start by building a temporary wall on each side as supports while you do the work. You then cut out the opening you want and install a header to replace the missing studs. Then finish it out.
