    Exclamation water meter keeps showing leak
    hello,i just moved into a new home,then had the water turned on,meter was showing a leak,pipes to house are good,because when shutoff valve is closed in home/meter stop showing leak,factory home tech has checked the entire house inside/and under this is a modular/mobile home,we check the flappers on all toilets/septic pipe for runon-good,no fitting leaks,we even switched out water meters,all the air is purged from the home/i cant move in till leak is found/please help!
    5,557
    Default Re: water meter keeps showing leak
    The first thing to suspect would be a toilet. Try turning the water off to the toilets or dump coloring or dye into the tanks. A small almost undetectable leak in a toilet can dump a lot of water.
