    Oct 2007
    10
    Default what kind of insulation for radiator pipes?
    Hi,
    I have a few runs of radiator pipes that are going through unheated areas in my crawlspace & entryway. I went to the home depot and bought some frost king foam pipe insulation that was rated for up to 210 degrees - but the largest size that they had didn't fit. My pipes are 1 inch thick.
    does anyone know of a pipe insulation that would fit 1" iron pipes that reach up to 170 degrees of heat??
    thanks for any help!
    -Amy
    Default Re: what kind of insulation for radiator pipes?
    I got some quality stuff from a plumbing supply house -- not sure of the brand but it has fiberglass inside and white paper on the outside (I have a steam system and one of the runs goes through an unheated garage). This stuff works great.
