Results 1 to 10 of 20
    Default drill adapter to square drive
    Tom was showing a tool that is an adapter that goes over a drill bit and adapts to a square bit driver. Does anyone know where I can get one.
    Pennsylvania
    246
    Default Re: drill adapter to square drive
    Quote Originally Posted by chefnewhope1 View Post
    it is call square drive socket adapter.
    You can find this at home depot, lowes hardware store or ******.
    http://images.google.com/imgres?imgu...%3Den%26sa%3DN
    Question Re: drill adapter to square drive
    Big Walt is incorrect. Tom was not using a square bit addapter.
    How would it work? The drill chuck had a drill bit inserted
    and the attachment went over the bit. There was no Square bit
    driver involved. The item Tom was using was anodized red or a similar color. It was also cone shaped! Please advise with the correct information. Thank you Jim L
    Pennsylvania
    246
    Quote Originally Posted by Jim Lambrix View Post
    FYI..I have not see what tool Tom is using.
    I was only going by what the OP said. "adapts to a square bit driver".
    Please Show me a picture of what Tom is using.
    I am looking for the same tool that Tom was using on "Ask This Old House" that aired on 10 November 2007. Tom was using a cordless drill with the bit in an adapter and after he was finished drilling the pilot hole, he placed an attatchment over the drill bit and was able to drive a square drive decking screw...hope that description helps.
    It was used in episode #606 of Ask This Old House where Tom was replacing some indoor mouldings...
    I think this may be it....try this link.
    http://www.leevalley.com/wood/page.a...411,43417&ap=2
    Here's another type that is similar idea.
    Has a drill bit for the pilot hole and a countersink cutter if needed..... just disconnect ..... flip it over ..... re-connect and you have the screw driver bit.
    Pictured with the square ( actually known as Robertson) bit.
ID:	376   Click image for larger version.
ID:	377   Click image for larger version.
    Pennsylvania
    246
    Thumbs up Re: drill adapter to square drive
    Guys, Thanks for better descriptions. Now I know what OP is trying to explain.
    Too me..a square drive means socket adapter. Wadda expect from auto technician.
    6
    Quote Originally Posted by BigWalt View Post
    Is this it?
