Thread: Will this work?
    31
    Default Will this work?
    Can I use a GFCI breaker on a circuit that just consists of a switch with a pilot light that controls an outlet outside in an eave?
    5,792
    Default Re: Will this work?
    Sure.
    31
    the gfci isnt for a lighting run. i want to use the gfci breaker instead of a gfci outlet because the outlet is in the eave
