Results 1 to 10 of 11
    5
    Unhappy Hanging a LIGHT - with no red, black or white wires?
    [FONT="Arial Black"]Hello...my question is below in purple if you don't want to read my life story...
    This may be a dumb question, but I can take it... after all I was a pastor for 25 years and well, nothing surprises me anymore.
    In my defense I was born and raised in a church owned home (parsonage) so if we needed work done, we'd have to call the trustees. Well, we bought our first home a year and a half ago and we've been slowly making improvements...
    Which brings me to my question:
    I purchased a used light, which has regular **** plastic wires... the wires are exactly the same with the exact same copper wire that has been spliced, there is however also a ground wire, I can handle that. QUESTION: Does it matter which wire on my USED light gets the black, white, or red wires?
    [/FONT]
    Thanks... so much![ATTACH][ATTACH]_pack[/ATTACH][/ATTACH]
    5
    Default Re: Hanging a LIGHT - with no red, black or white wires?
    Almost forgot... thanks in advance!
    Alfetta159 Guest
    No.
    With the exception of the ground wire which should be connected to the metal box that the light mounts on.
    Denver, CO
    666
    I can tell you what "should" be but I can't see it from my office so I can't tell you what "is".
    Ready?
    Okay, on the lamp socket the shell, the threaded part of the socket should be the white or neutral and the little tab in the bottom of the socket should be the hot or black/colored wire. On your cord you should find writing and/or a rib on only one of the pair of wires and this should be connected to the neutral or white wire.
    A simple continuity tester would tell you a lot if you remember that the socket shell should be the neutral/white.
    Shoulda, coulda, woulda
    6,115
    What Kentvw said is correct. When you use a continuity checker to find out which wire is connected to the center button in the socket wrap some black tape around it so you'll know the next time.
    5
    If I knew what a "continuity checker" was for I probably wouldn't have been looking for the answer on here... yikes, now I AM confused. Thanks anyway...
    5
    Default Grammar was bad ?
    If I knew what a "continuity checker" was for, I probably wouldn't have been looking for the answer on here... yikes, now I AM confused. Thanks anyway...
    For the light to work it doesn't matter which wire goes to which ... the light will work.
    For the proper safe way ....the **** colored wire with the rib or writing will connect to the white wire in the electrical box.
    The other **** wire from the light will be connected to the black wire in the electrical box.
    Hopefully that helps.
    Oops ... large font ... looks different eh?
    5
    [ATTACH]_pa[ATTACH][ATTACH][ATTACH][ATTACH]Click image for larger version.
    Upon further review... I thought I'd investigate a little furth... there was some electricians tape wrapped at the base where the wires go into the actual "base" or whatever you call it. Thought I'd take a picture of the light... maybe you'll understand... as I started to say... I noticed there is some darkness on a wire like it was getting hot... wonder if it's even safe to hang now? Although, that's probably why they had all that electricians tape.
    I'm all ears, or EYES...
ID:	366   Click image for larger version.
ID:	367   Click image for larger version.
ID:	368   Click image for larger version.
    612
    Some questions to see if I'm understanding this correctly. Are there 3 wires in the ceiling you have to choose from, a red, black and white? Are there 2 wall switches that control this light or one?
    By the way, we had a couple of hanging light fixtures that had what looks like the same type of wire. They also became "burnt" looking and I changed out the cheapo stranded lamp wire for solid 14 awg wire.
