Thread: drains
    Default drains
    I recently had a new sink installed and now it drains very
    slow,could air have gotten in the drain pipes?thanks
    6,047
    Default Re: drains
    No, the drain pipes normally only have air in them. The water and waste drains away.
    2,009
    Default Re: drains
    Maybe something fell down the pipe & is partially clogging the drain. The first place to look would be in the p trap. It's pretty east to remove & check. Or snke the drain if possible.
    35
    Default Re: drains
    Did it drain this slowly starting immediately after installation, or did it slow down afterward? I.e., has there been any change from the moment it was installed?
