    Seal Beach, California
    8
    Default Heating in CAlifornia - Furnace or Heat Pump
    Can anyone suggest wich way to go with heating in California - use the regular gas Furnace or Heat Pump (do not know if they are used in CA). Can Heat Pump be used for both - AC and Heating?
    I have an old gas Furnace Rheem brand (with ducts) and no AC at the moment...
    Though maybe switching to Heat Pump will give me both - cool and hot air...? Thank you in advance.
    Jul 2009
    Northeast
    661
    Default Re: Heating in CAlifornia - Furnace or Heat Pump
    A heat pump would work great in CA. and yes they are for both Heat and A/C. Good Luck!!!
    Iowa, Quad-Cities area
    129
    Quote Originally Posted by californian View Post
    A heat pump in Calif. is a good idea.
    For comfort and quiet, I would recommend a staged,
    "variable-speed" furnace with a two-speed heat pump.
    Because heat pumps require "special needs",
    you need to find someone that knows what's he/she is doing.
