    Angry pressure reducing vavle problem
    I just put in a new prv(pressure reducing valve)now when I open any facet I get a high pitch squill. What can I do to fix the problem?
    1,131
    Default Re: pressure reducing vavle problem
    What is the pressure set to?
    Sounds like it may be too high.
    Adjust to 70 psi or less and see if that remedies the situation.
