    Nov 2009
    Default Adding Attic insulation
    I am adding insulation in an attic, there is existing fiberglass insulation from 40 years ago when house was built, I will be using formaldehyde free insulation from JM, is it advisable to first remove the old ins. which probably contains formaldehyde, or just install new over old ?
    Default Re: Adding Attic insulation
    Any concerns of formaldehyde would be from "off gasing " however after that length of time I highly doubt there is any off gasing occuring.
    You should be fine with leaving the old insulation in place and cover over with the
    new ------- making sure not to use faced batts.
    Jul 2009
    Northeast
    661
    Follow this link for a wealth of off gassing info. Good Luck!!!
    http://www.wisegeek.com/what-is-offgassing.htm
