Results 1 to 8 of 8
    Oct 2007
    Default Richard Trethewey Tools
    What are the type pliers that Richard uses. And what other handy tools doe he have in his bag of tricks?
    thanks, Pete
    5,836
    Default Re: Richard Trethewey Tools
    They are called "water pump pliers".
    If it's like the one in the attached ... it's official name is "tongue and groove plier"
    But like jack said .. commonly referred to as water pump plier or even channel lock pliers. They are available anywhere even WalMart.
    Oct 2007
    175
    They're actually "slip joint pliers."
    Chicago, IL
    162
    Libcarp, "slip-joint pliers" are the old fashion regular pliers. "Channel Locks" and similar pliers are actually "groove-joint" pliers.
    HTH
    Dave
    libcarp ..... If you look closely at the channel locks you will notice one section has grooves the other section has the mating tongue ... that's where the reference to tongue and groove pliers comes from.
    These are slip joint pliers
    5,836
    Channellock is a manufacturer of many types of pliers, tongue and grove pliers come in a variety of styles including pater pump pliers.
    Georgia
    150
    I'm not sure what else he uses but I have found that "Aligator Pliers" by Knipex are the best thing I've ever used. They are made to tighten more with the more force you put on them. I've used them to remove stripped nuts/bolts as well as for a pipe wrench. They simply will not slip. I keep one pair in my work truck and one pair at home. You can get them at Ace Hardware.
