    Oct 2007
    Red face Shower Head Dripping
    I have a shower head in the master bathroom that keeps dripping. I was thinking it was the actual head but starting thinking about it and pondering that it could be the on/off valve. Anyone know what could be causing the continuous dripping?
    612
    Default Re: Shower Head Dripping
    More than likely it is the valve. What type do you have? It could be something as simple as an "O" ring on a valve stem that is relatively easy to replace.
    Oct 2007
    It is a delta.
    6,486
    Single handle or double handle? Single handles have a cartridge that uses cup washers to do the sealing. Sometimes the entire cartridge needs to be replaced. Double handles use flat or cone washers. Both are easy to repair.
