Thread: Squeaky floor
    Oct 2007
    Default Squeaky floor
    Hi ,
    Can you buy a tool that will locate the joists under carpet so i can drive screws to stop squeak???
    Thanks Ron:
    6,045
    Default Re: Squeaky floor
    Go to Rockler and get a "Little Wizard" metal detector. The subfloor is generally nailed or screwed to the studs. Locate several of the nails, this shoud give you a line that follows the studs.
    Maryland
    2,008
    Rather than driving screws through the carpet, a better way to do it is to pull up the carpet & then you can see where the nails in the subfloor are & you can install screws.
    6,045
    Ed,
    If you only have a couple of spots that squeak it's easier to use a Squeek-No-More-Carpet-Kit than pulling up carpet and getting the proper tools to reinstall it.
    Oct 2007
    Thanks for the reply will give it a try.ron
    another scottish quote you might use
    Having a drink with friends
    Quote" here ta us whae's like us damn few and they are all deed
