Thread: Windows
    Question Windows
    The wood on the exterior window frame to the house is rotten. There are four sides which makes a square and the top part of this needs to be removed. How easy or hard is that to remove and replace?
    5,939
    Default Re: Windows
    Generally it's quite easy to remove a window frame. Usually all you need to do is use a utility knife to break the paint along the edges and pry out.
