    Oct 2007
    8
    Default floor joist and parallel partition wall
    Dear Sirs,
    I have looked carefully and now I see the joist running parallel to
    the cement block wall. I have found a diagram in the "Basic
    Carpentry" book:
    IMAGINE A RECTANGLE WITH A VERTICAL LINE DOWN THE
    MIDDLE. THESE ARE THE LOAD BEARING WALLS, EXTERIOR
    PLUS ONE INTERIOR. A HORIZONTAL LINE IN THE MIDDLE
    OF THE RECTANGLE JOINS THE CENTER VERTICAL LINE.
    THIS HORIZONTAL LINE IS THE PARTITION WALL.
    vertical load bearing
    .....vertical bearing
    ...............V
    ____________________________________
    llllllllllllllll
    llllllllllllllll
    llllllllllllllll
    llllllllllllllll
    llllllllllllllll
    llllllllllllllll
    llllllllllllllll
    lllllllllllxxxxxxxxxxxxxxxxxxxx
    llllllllllllllllllllllllllllllllllllllllllllllllll l <partition
    lllllllllllllllll
    lllllllllllllllll
    lllllllllllllllll
    lllllllllllllllll
    lllllllllllllllll
    lllllllllllllllll
    ...............^bearing
    This is the basic structure with one inside load bearing wall (vertical line).
    The floor joist near the "xx" on the diagram is very rotted. Also,
    the book describes how to build a partition wall. They mention that
    the sole plate has to be nailed to the subfloor, and in the case of
    masonry floors the sole plate of partition should be fastened with
    expander bolts (anchors). My hollow concrete blocks on which
    the partition sits do not seem to have any anchors or drilled holes
    for anchors.
    First, I want to concentrate on the floor joist, which is rotted at
    one end. Would it be wise to simply place a new 2x6 beside
    the old one (sistering)? In the living room I measure approx.
    112 inches from wall to wall. Then if I add the width of the
    concrete blocks, I get 112 plus 8 plus 8 or 128 inches
    (10 feet 8 inches). Is there a standard length for a floor
    joist? I have seen a joist replaced once. The carpenter
    took almost the whole subfloor off and replaced the structure.
    Since I have only one rotted end, is it possible to put a 2x6 joist
    in position by working in the
    crawl space and leaving the subfloor intact?
    thanks, Paul serapions@yahoo.com
    14
    Default Re: floor joist and parallel partition wall
    I really don't follow your whole description, but in general, yes, I'd (hurry) "sister" a new floor joist next to the one with a rotted end. That may be tough is the floor is sagging a bit, so you'll want to determine that first. If it is sagging, you have anothe rset of issues to contend with: 1) do you leave it and try to support the one rotted joist in a nother place, or 2) do you jack up the whole floor to insert a new straight joist and risk messing up something else upstairs when I jack it up. Good luck.
    1,673
    I don't quite follow either, but how did the water get in to rot the joist & have you corrected the situation.
    Leaving rotted structure in place isn't usually a good idea. Also be sure you don't have termites.
    If you do leave the joist at least cut it back to good wood.
    The plate should be replaced if rotted. If the replaced piece is relatively small don't worry about anchoring to the block, nailing or some strapping will be okay.
    The existing sill is probably anchored to the block every 4' to 6'or so. The anchors may be straps or bolts imbeded in the block.
    Their is no standard joist length, but the span it can handle is determined by its size, spacing and loading.
