    Oct 2007
    Default Cracked Lath&Plaster walls
    II would like to find out more about the adhesive system Tom featured on the show,the brand name &where to purchase it & whether it comes with the plastic buttons needed for the project, Thanks
    delineators[0].length));**<>"][/SIZE]
    Default Re: Cracked Lath&Plaster walls
    I think you will find this article of use. http://www.thisoldhouse.com/toh/arti...628100,00.html
    good luck...PM
    6,055
    Here's the product you are looking for http://www.bigwallys.us/ click on "Painters Pack" or "Contractors Pack".
    7
    I have a resin based plaster product that will adhere to the existing lath, bond to remaining surrounding plaster, and is easily worked to the same level of surrounding plaster. It is sandable, and water resistant. This product can be used to skim coat plaster walls. It also adheres to wood, tile, glass, concrete. Please email bjmten@gmail.com
    Brian
