Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Oct 2007
    56
    Default Re: compression fittings
    sry my last post was to spruce
  2. #12
    7,155
    Quote Originally Posted by ****hiller View Post
    "Now if ****ie would just open up his apprenticeship program, none of these problems would be an issue ... "
    Ha! Don't I wish.
    Remember.......90% of learning is a negative experience. I've had my share and have more most everyday. Argh.......
    Aaarrrrghhhh, ye pirate side, she be show'n me matey!
    But, but, I've already learned all the stuff I'm not supposed to know. Now I wish to know all that is ****en!
  3. #13
    7,155
    Quote Originally Posted by murphmgh View Post
    And my answer would still be the same- no, compression fittings make a poor substitute for a solid connection, particularly when that connection cannot be accessed at will should the need arise.
  4. #14
    The deep South
    459
    It depends on the application . I just didn't agree with a rubber stamp condemnation .
  5. #15
    5,825
    Quote Originally Posted by djohns View Post
    It's not a condemnation of all applications or types of compression fittings just the type used by homeowners for water lines. I'm sure you wouldn't use one of those for high pressure gas lines or pressurized hydraulic lines. If you do I wouldn't want to work around there.
  6. #16
    The deep South
    459
    Expensive and as with all mechanical joints problems with vibration and movement.
    Reread your own post J.L. " as with ALL mechanical joints "
    I stand by what I said .
  7. #17
    5,825
    My apology, I shouldn't have been so general in my answer but I stand by my opinion of those compression fittings.
    By the way around here the compression fittings used on gas lines and hydraulic lines are also flared and in the case of hydraulic lines are double flared.
