Results 1 to 9 of 9
    Oct 2007
    Default Dirty shower tile
    The tile floor in my shower is dingy and seems to have a film on it. I have sc****d it but that's too time consuming. I have tried various cleaners, nothing works. Should I power wash it?
    What else will work to make the tiles come up like new.
    Sep 2007
    Long Island, NY
    269
    Default Re: Dirty shower tile
    Might be a funny answer coming from someone's that been doing renovations the past 30+ years but the industrial TILEX you get in your supermarket is pretty powerful stuff. You really need to keep the windows open when you use it. the fumes are pretty intense. I found it to work really well.
    Hidden Content
    ॐשָׁלו
    Oct 2007
    Thanks for the reply. I'm pretty sure I used that already, but will give it another try. Any other suggestion are appreciated!
    Sep 2007
    Long Island, NY
    269
    For the most comprehensive answer to your question you will find it here
    http://www.johnbridge.com/vbulletin/index.php?
    Look in the "Liberry" there
    http://www.johnbridge.com/vbulletin/...itle&order=asc
    and post the questions as well.
    You will see an ad for Stonetech in the Liberry up top of the page...they have some incredable products.
    Hidden Content
    ॐשָׁלו
    Oct 2007
    132
    Have you already tried good old sudsy ammonia and a scrub brush? Straight ammonia, scrub, wipe up with paper towels and on to the next section. Carry the ammonia filled paper towels out regularly.
    Be sure to keep the fan on and the windows open.
    Don't use it if you've recently used bleach anywhere in the house.
    New York
    37
    I have found that Scrubbing Bubbles works great to get off caked on soap scum and water stains. Good luck!
    1,903
    I found Scrubbing Bubbles works well too. Spray nearly the whole can over the area & let it set for at least a few hours. Spray again & scrub with a brush.I usually wet the area first.
    Running the exhaust fan is a good idea.
    Georgia
    150
    I have had great results with rubbing alcohol in a spray bottle. I also liked the idea of the steam cleaning system.
    Try using a few dryer sheets.. Just rub dryer sheets on tile/glass doors w/ a little water. The soap scum comes off in no time!
    Also - the Mr Clean Eraser works sooooooo well!
