Thread: Vapor barrier
    Olathe, KS (Kansas City)
    6
    Default Vapor barrier
    We purchased our house with an unfinished lower level. The city said that the paper backing of the exposed insulation in this unfinished area was a fire hazard so the builder removed the paper but left the fiberglass. I am going to finish this now, should I put up plastic to serve as a vapor barrier. Any advice on what I should do is appreciated. Thanks.
    1,131
    Default Re: Vapor barrier
    Depends.
    Questions to to start.....
    What is your locale and by "lower level".....do you mean a basement?
    (I presume this is fiberglass batt insulation. ? )
    6
    I think they refer to it as a walkout lower level. There is a basement down from this level. And yes it is fiberglass batt insulation. Thnaks.
