    Nov 2009
    Default Sound Proofing Floor/Ceiling
    I plan to add a second floor to my current range house to make a two story house. What is the best way to soundproofing the floor/ceiling to reduce/eliminate the footfall/impact/airborne noise between the ground floor and second floor. Any recommendation on the products in the market to solve the problem. Thanks.
    6,023
    Default Re: Sound Proofing Floor/Ceiling
    Foam insulation might be a good choice.
    Dec 2009
    MIchigan
    68
    Foam is actually the worst choice. Counter-intuitive as that sounds, it's lab-proven to be the case.
    Standard R19 fiberglass is as good as it gets.
