    Oct 2007
    Thumbs up Super easy way to drive a new grounding rod
    Driving a standard eight foot grounding rod can be a hassle at times, especially the last couple feet. Try this....simply take a 1/2" nut and place it on the ground where you want the rod. Then place the rod into the hole of the nut and then drive it in all together. The nut displaces the ground as you drive it down and it is very easy to drive because the ground isnt causing friction on the rod. When your done just slowly dump a gallon of water on the rod to allow the ground to make contact with the rod again. You wont believe how easy this is.
    Chicago, IL
    162
    Default Re: Super easy way to drive a new grounding rod
    We just use a roto-hammer. Instead of installing a chisel or bit, just put the roto-hammer on the end of the ground rod & squeeze the trigger.
    "You wont believe how easy this is."
    HTH
    Dave
    Shamokin, Pa.
    645
    I always assign that task to a helper. Can you say HILTI?
