Thread: stain in marble
    Nov 2009
    Default stain in marble
    How do you get grease out of carrara marble?
    980
    Default Re: stain in marble
    make a poultice out of powderd chaulk and acetone or chaulk and mineral spirits. cover with plastic for 24-48 hours. it may have to be repeated to completely remove the stain. it may take up to 5 applications to completely remove stain. rinse with water and buff dry.
    Nov 2009
    Are you sure this will work? It is on Italian white carrara marble?
    Aug 2009
    Ladson,SC
    192
    Quote Originally Posted by vikki1930 View Post
    You can use the Poultice above or order from ProSOCo Inc.
    Check on page 2-43 Marble Poultice ( Sure Klean )
    980
    this is what will have the best chances of working. a simple poultice like this is exactally what we use. you usually don't tell the coustomer what it is that you use because if they know they won't come to you to get the stains removed and there goes some easy money from your service dept. Yes I'm sure it will work
