Results 1 to 10 of 15
    Oct 2007
    Default Old pull chain light socket repair
    Our 100 year old farm house has ceiling lights that are suspended by their own wires. One of the pull chains has pulled out, and I can't figure out how to open the socket housing inorder to replace the chain. Advice on how to open the top cap would be most appreciated.
    Regards, LL
    8,046
    Default Re: Old pull chain light socket repair
    Can you provide a picture of the fixture in question? The sockets that I'm familiar with basically "twist lock" together. The second image in this link shows what I'm referring to. http://www.hometips.com/content/lamps_ef.html
    Some ceramic fixtures are screwed together, there is a porcelain ring that screws down over the socket to hold it in place, simply unscrew the ring and you're in.
    Whatever you do DO NOT work on an energized circuit! Turn off the breaker (or remove the fuse ) then test the socket with a voltage tester to be certain it's deactivated.
    Oct 2007
    Thanks. I wish I could send a photo. The assembly I have suspends from the ceiling from a two piece ceramic mount. The lower half has electrical tabs that twist lock into electrical tabs in the upper half. So I'm disconnected from the power.
    Unlike the socket you showed, the socket housing I have has a smooth flange where cap fits over barrel. There is a stamping on the barrel that reads: 250W-250V
    GE Co. USA
    The socket is in good condition with only minor surface oxidation. I just can't seem to get the cap to twist or slide in any direction in order to reassemble the pull chain to the switch.
    Regards, LL
    8,046
    I knew the image that I attached wasn't exact to your situation, it was to show the "twist lock" that I was referring to.
    I will leave further comment to the electrical pro's. Do let us know how things work out.
    Denver, CO
    666
    I think any "electric pro" that could answer this question is either playing a harp or has his tail on fire.
    Maybe not.
    Are there any screws on the inside of the socket??
    Oct 2007
    Thanks. There is a screw inside the lamp socket that is not associated with the electrical contacts. I think it may connect the inner socket to the rotary switch ass'bly. I say this because the two move together with a small amount of play inside the socket housing and cap.
    There is only one other screw head visible; inside the cord opening. It seems to be the center axis for the rotary switch, as I can feel the spring tension as I manually operate the switch with a screwdriver.
    You're probably right about the old guys. It'd sure be sweet if one of them is reading this forum.(from anywhere!)
    Later, LL
