Results 1 to 10 of 11
    Oct 2009
    15
    Default Creative Kitchen Project - pot filler faucet
    I want to install a pot filler faucet for my wife for Christmas but purchasing one is outside of our spending cap for xmas gifts. I want to make one out of standard plumbing fittings but can't seem to find a stem that swivels, or find the right combination of fittings that does the trick. I would like to make it out of chrome covered piping, but copper would be OK to. It doesn't have to be pretty, just work. I figure it'll look industrial chic. The supply would come from the 1/2 inch flexible tubing running from an undersink filter to my existing faucet, I figured I would just put a "T" fitting on that somewhere. That way the pot faucet water is filtered also. I would want there to be 2 shutoffs, one at the faucet head or the wall (accessible), the other under the sink.
    The piping can be exposed, and clamped to the wall along the backsplash until it gets to the point that has to swivel. Any assistance would be greatly appreciated. I feel like someone who knows faucets really well will know the exact parts I need.
    In a pinch I was thinking of running flexible tubing inside of the copper pipe, so the copper would just be the frame and the raceway for the flexible tubing. Then the pivot point could just be a threaded copper fitting that I leave loose, but this seems to have other problems, like the joint being rigid enough to stay where you want it, and attaching the faucent head at the end to both the internal and external pipe...
    Again, any help is greatly appreciated!
    -Kevin
    Jan 2009
    Taxachusetts
    136
    Default Re: Creative Kitchen Project - pot filler faucet
    post a picture of sink and x where you want the faucet, exposed lines are sort of cheesy if not done right.
    Shaun
    You could probably craft something out of regular copper pipe, but the results would look rather cheesy. Even finding an inexpensive valve isn't going to look all that great on exposed piping.
    If none of that matters, then I would plumb from the sink to behind the stove with flexible copper. Start and end the run with a ball valve - 90* turn to operate on/off. Out of the ball valve, install a hose nipple. Next would be to craft the spout arm. This can be as simple as an "L" shaped piece of rigid pipe that is held to the wall with pipe clamps or more aesthetic may be to use a piece of rigid pipe one size larger as a wall sleeve. On the end of the "L" behind the stove install another hose nipple, on the other leg of the "L" that will service the stove top, install a downward facing elbow and a short length of pipe. If you can find an aerator that you can graft on it would be best. All that's left is to connect the wall arm to the supply line with a length of hose. If you can make up the joints with copper solder rather than silver solder, the whole system can be polished up to look pretty decent.
    Oct 2009
    15
    A. Spruce - Thanks for your answer, I really appreciate the fast response. Unless I am missing something, though, your solution does not include a piece that pivots/swivels/hinges. I need the faucet piece to sit flush against the wall when not in use, and then swing out over the pot to fill it. I was figuring that if kitchen faucets can swivel, then maybe I could leverage that technology to build my pot fillter faucet. What do you think?
    It's possible, but probably a pretty tall order for the average DIY'r.
    The swivel spout in my description was the "L" shaped piece. You'd hold it to the wall with either pipe hanger clamps that are a size too big, or with a sleeve made from a larger piece of pipe. The hose connection from the supply to the "L" would create the hinge point.
    Oct 2009
    15
    This sounds really good, and much simpler than what I had in mind! In my head I'm trying to think of a way I can enclose the whole thing in sleeving that is either chrome, or stainless steel. Maybe even that stainless steel paint I have seen.
    One question, when you swivel the faucet part out from the wall 90degrees, so it is not perpendicular to the wall, what holds it in place? I have something in mind but I am betting you'll have a better idea than mine. Please let me know what you think, and thanks.
    -KH
    If you're lucky, the hose would allow enough pivotal movement through it's coupling. If you're not lucky, then you'd have to install a collar something along the lines of a glueless coupling, though in this case it would only be snug enough to keep the spout from moving on its own.
    If you actually build this thing, take lots of pics and post back.
    Oct 2009
    15
    OK, tell me what you think of this idea, since I'm already going to use an oversized pipe as a sleeve for the piece of hose, I could siply put a cap on it. I could cut the cap, or the pipe above the cap to allow the smaller inside pipe which is connected to the hose to sit flush against the wall, or lift up, slide in a groove, and sit in a notch so that it stays perpindicular to the wall. I have attached a crude drawing. I was thinking something like a slide bolt door lock.
    That would probably work well. IMHO, you're going to want to keep as much of the wall mount and other unsightly things down below the back of the stove, so rather than notching the bottom of the tube like that, you could easily notch the top.
    Oct 2009
    15
    I'll post a picture of my kitchen, stove, and counters tonight or tomorrow, and maybe that'll make it easier for us to communicate. I like the idea of it being above the counter and stove so I can see it, and see if there are any problems/leaks. But I also like the idea of it going behind the counter and stove, so it is hidden. Is it OK to run water behind the stove like that? (it's a gas stove if that matters) It also would be passing under an electrical outlet, and near the electrical outlet for the stoves starter. (I know I will have to make those outlets GF outlets now, which is OK by me.)
    If it's hidden I could do flexible hose the whole way, and then do the nipple, tube inside a tube pivoting right at the very end.
