Results 1 to 8 of 8
Thread: Screen door
    Oct 2007
    Question Screen door
    Hi,
    We had guests at our house this afternoon and one of them walked into our sliding screen door as they were trying to get out onto the deck. It jammed immediately, but we got it to move enough for them to get outside. Since they left we've been trying to fix it but with little success. We can get the bottom to move quite freely, but the top won't budge. We've tried adjusting the screws at the top and that doesn't help at all. Any suggestions?
    Thanks,
    Al
    6,115
    Default Re: Screen door
    He probably knocked the rollers of the track. You should be able to left it up and pull the bottom out then the top. Reinstall aligning the upper rollers on the track then slide the bottom in. You may need a screwdriver to lift the bottom rollers onto their track.
    Sep 2007
    Long Island, NY
    269
    Quote Originally Posted by butal1 View Post
    Hi,
    Thanks,
    Al
    Uhhhhh...what was he drinkin'? LOL
    What JAck said but if that doesn't work take some close up pictures so we can see what kinda door it is. some are different than others.
    Hidden Content
    ॐשָׁלו
    If it's an aluminum slider, odds are the top track may have been tweaked a little. Hopefully it's just the rollers, if not, check the top of the door for bends or damage, anything that would cause binding in the upper track.
    Oct 2007
    Thanks for your help. I had a good look at it this morning and still could not fathom it out. Then my daughter decided to take a look. I was back inside the house when she yelled "I've done it". The door was unjammed and she and I lined it up and now it's sliding smoother than ever before!
    Sep 2007
    Long Island, NY
    269
    I can see the side of your truck now...lol
    BUTAL1 FIX's STORM DOORS INC
    FATHER AND DAUGHTER TEAM
    Hidden Content
    ॐשָׁלו
    Or Butal1 & Daughter Door Service for short ...
    Glad you figured out the problem and thanks for reporting back your results.
    Jul 2008
    47
    You go girl!
