Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Default Re: Grounding old oulets
    How about variable speed drill with 3 prong plug?
    How about a refrigerator with a 3 prong plug?
    How about an antenna rotor control with a 3 prong plug?
    There are a lot of 3 pronged items used in the home.
    The point is about electronic equipment ... not about 3 prong devices.
  2. #22
    Do you know why the newer 2 prong plugs have a wide and a narrow prong and why it is important to wire up a lamp with the right wire to the narrow and wide prong?
    Okay you's wise guy's............. If you are using two wire "zip" cord to feed said socket in a table lamp which wire should be used for the neutral?
    There could be some ribbing with answers that are polar opposite.
  3. #23
    Oct 2007
    SF Bay Area, CA
    To redirect this thread back to its topic...
    I recently replaced an old receptacle in my 50+ year old house and found that its "grounding terminal" was connected to the neutral/return terminal via a short thin wire. Other then that the outlet box only had the usual black HOT and white Neutral wire inside (no ground wire).
    Has anybody seen such a thing before and can explain the benefits/risks of such a "grounding".
    Thanks for your help/input!
  4. #24
    6,047
    Quote
    Canuk,
    Heave you ever opened a variable speed drill, electronic control board. Plus other 3 pronged devices that require a ground for safe operation.
  5. #25
    6,047
    [quote=mreckleben;5240]To redirect this thread back to its topic...
    Thanks for your help/input![/quot
    This is absolutely the wrong thing to do. The common is used as a current return. The ground should must be a ground wire to provide the safety it is suppose to provide.
