Results 11 to 20 of 25
  1. #11
    Denver, CO
    666
    Default Re: Grounding old oulets
    Kent,
    Andy stated that a ground rod was installed a a ground wire was run to the panel.
    Even those surge suppressor power strips used to protect computers from surges require a ground to work.
    Andy did state that the wire was brought to the panel but did not elaborate on whether the neutral was then bonded to the grounding system at that point. Point being
    that if any "hot to ground" fault occurs the breaker will not see enough of the fault and will not trip unless that bond is made. This is more of a life safety hazard than having no ground at all.
    I had not thought about it at the time but you are 100% correct on the power strips with regard to surges and electronic protection being cleared back to the grounding conductor.
    I usually try and answer electrical questions per NEC and like the NEC with life safety taking priority over all.
  2. #12
    6,047
    Kent,
    You've made a good point about the neutral /common junction. I may have errored in thinking that if an "electrician" did the job he knew that. I shoudn't have considered the rest of what he said.
  3. #13
    Kent,
    Electronic equipment use filters to ground to remove electrical noise, surges, EMI, and RFI . It may be as simple as an RC network tied to ground to some fairly complicated circuitry. Even those surge suppressor power strips used to protect computers from surges require a ground to work. In doing surveys before the installation of electronic equipment, a proper ground was one of the first things we checked for and required. Jack
    Jack ... wouldn't this only apply to devices with a ground plug ... any device that has only 2 prong plugs wouldn't have this consideration.
  4. #14
    6,047
    Canuk,
    You are correct 2 prong plugs do not need ground but how do you know what is going to be plugged into the outlet. It may be a lamp today and tomorrow they may rearrange furniture and put a computer desk there.
    Do you know why the newer 2 prong plugs have a wide and a narrow prong and why it is important to wire up a lamp with the right wire to the narrow and wide prong?
  5. #15
    Denver, CO
    666
    Ohh,Ohh, I know, I know!
  6. #16
    Canuk,
    Yep ... what will be plugged into the outlet can change.
    Sorry I wasn't clear with my post .... to qualify electronic equipment.
    You mentioned : Electronic equipment use filters to ground to remove electrical noise, surges, EMI, and RFI . It may be as simple as an RC network tied to ground to some fairly complicated circuitry ... these would have a three prong plug. In cases it would be ideal to provide isolated and dedicated grounded circuits to these but not very practical for residential applications.
    You are absolutely correct in order for them to utilize the filtering circuitry they would require a grounded circuit .... though they would operate on a non grounded circuit just without the proper filtering designed into them .
    The common AC powered electronics that utilize a two prong plug won't have this consideration since they don't require and have no connection to ground.
    Oops... straying off topic a bit.
    What's the prize ... a NEW car or a Halloween pumpkin ?
    Attached Images Attached Images
  7. #17
    The deep South
    459
    Here's a hint . " Lamp socket "
  8. #18
    Denver, CO
    666
    Okay you's wise guy's............. If you are using two wire "zip" cord to feed said socket in a table lamp which wire should be used for the neutral?
    Go ahead................ no fair googling either.
  9. #19
    6,047
    How about variable speed drill with 3 prong plug?
    How about a refrigerator with a 3 prong plug?
    How about an antenna rotor control with a 3 prong plug?
    There are a lot of 3 pronged items used in the home.
  10. #20
    6,047
    Quote Originally Posted by kentvw View Post
    Kent, The real question is why?
