Thread: dryer problem
    Oct 2007
    Default dryer problem
    i have a frigidaire stackable washer/dryer unit. a week ago i was using the dryer and i stopped it to check on the clothes and when i went to turn it back on it wouldnt start. i was told that it is the door safety switch and all that i have to do is cut the wires and put the wires back together and bypass the switch. was i given the wrong info or did i do something wrong. which wire should i put back together black,white,grey. the dryer still isnt working could it be something else, i have no clue how to fix dryers. i need this dryer to work, i have 3 women in the hous eso they need clean clothes, help please
    1,694
    Default Re: dryer problem
    I've had good luck with repairclinic.com. Parts took less than 2 weeks to arrive.
    They have good trouble shooting guides & accept email questions I think.
    I thought I ansered this before
