    Oct 2007
    Default earring down the sink drain
    I recently dropped an earring (my only, teenie little diamond stud) into the sink in my bathroom, and of course it rolled right down the drain.
    Is there any way I can retrieve this? It looks like the pipes under the sink make a "U" shaped curve. I don't know how to get the pieces of pipe apart and am not sure I can put them back together!
    Thanks for any help/advice you can provide.
    Kathy
    Sep 2007
    Long Island, NY
    269
    Default Re: earring down the sink drain
    You can get a plumber in for $350
    or twist the lock nut rings on the upper and lower end of the U and you should be able to jiggle it apart.
    Take loads of pictures as you do it and number them 1-50 so you don't forget.lol
    When re-installing start from picture 50and work your way back to 1
    Hidden Content
    ॐשָׁלו
    Oct 2007
    132
    I did that too, but with an ordinary contact lens. Went over across the street to a handy plumbing co. and explained the situation and asked to borrow a pipe wrench (someone i worked with told me how to get the trap off), and the owner handed a wrench to one of his guys and sent him over, free. I must've looked like the village idiot.
    Well, he showed exactly like Andy said, but he did one more thing - the put my dishpan under the trap and that was good because water and the lens went into it. Then he watched while I put it back together.
    What comes apart goes back together in the reverse order he said. And it didn't even leak. woohoo!
    So the main thing is, put a dishpan or something under the drain when you take it apart.
    May 2009
    Smile Re: earring down the sink drain
    There is a MUCH easier way. Just put some fine mesh (panty hose, etc.) over the end of a shopvac hose, and suck it out. Go to this link for video instructions...
    http://www.familyhack.com/2007/08/29/drain-tip/
